I have a Gen IV BBC. The oil pressure has been on the lower side ever since I've been using a BBC. My first block was a Gen VI, I roached the bottom end, trashed the block. I got a new block, new pump, all of it. So far I've had to rebuild my bottom end each year. I have always used SBC's, and never in my time racing have I ever had an issue like this. I've tried a different pump, pickup's, pan's, windage trays, and oil weights. I've been using Melling pumps, which I've always seemed to have no issues with. I just purchased a high pressure spring, but haven't put it in yet. I had 10W40 Synthetic in it and after 4000 RPM, the pressure would hit 60psi, then fall off. I took some oil out, just to be sure it wasn't roping, but it continued. The other day I put straight 50 in it, and now it goes to 60 psi, and stays there even after passing 6000 rpm, which I left off the pedal. Normal driving is not a problem. I am probably missing something so simple it'll make me look like an idiot, but I really don't want to wipe out another rotating assy., and I don't want to buy a $5-600 pump. Any ideas please.....
