ARP rod bolts 8740 vs 2000 vs l19
53K views 26 replies 13 participants last post by  steven.evans330
What are the hp limits of the 3 different rod bolts they offer?
#2 ·
Well, I decided to call ARP and see what they said, lol. They do not have hp ratings for their different metals. He said they leave it up to the end user to decide which ones to go with. I asked why should I go with a 2000 or L19 over an 8740 and he just said its really up to you and what you wanna do with the motor. wtf?
#5 · (Edited)
I would think piston/rod weight, stroke, rpm would be more of a factor than a HP rating. I look at it as a package since in the end it's only as good as the weakest link.
Gotta love some of the tech guys. I called Comp Cam about my combo and a cam I thought would be good. Guy said...." Uh yeah, that should work" I won't even get into my contacts with TCI. :rolleyes:
#6 ·
I thought at one time i saw a chart, it may have been in eagles book with thier rod bolt selections and HP ratings. 6" H beam with the 8740 i thought was 750 HP and with 2000's it was 1100 hp or something.
#7 · (Edited)
Rod bolts load is largely dependent on stroke and reciprocating package vs RPM this is more of a factor than HP. So as an example a turbo motor of 526 inches making 3500hp will be a LOT easier on rod bolts than a 1000 inch Leonard motor making 2150hp due to the enormous FPM and package weight of the bigger motor.
That said look at it this way if a 900 inch motor with 4 hits can live with l-19 bolts a full on 275 motor would probably live with 8740. Now if you wanted to upgrade to 2000 that would be fine but to me the L-19 is overkill and also the L-19 is a tricky material that requires care to avoid hydrogen embrittlement due to exposure to chlorinated hydrocarbons and the like.
#23 ·
Had always wondered how rod bolts were rated by by horsepower... instead of RPM, stroke and piston mass... as during the power stroke, the rod is under a compressive load, and the rod bolts are just along for the ride. Rod bolts are not under tension on the power stroke.
#24 ·
Probably ARP makes those 1.400" under head 2000 7/16" bolts under contract to the rod company and can't sell them to individuals. (Replacements for Eagle rods are done that way, as are Molnar.) Callies/Compstar has them listed as replacements for SBC small journal 6.000" rods. I have a set of those rods here and am going to order replacements during the rebuild, from Callies. The part number is on their site. These have an undercut between the threads and the head of the bolt.
