How much air pressure do you run in your accumulator?
Gary I agree with everything you say...except that if the extended piston air pressure is 20 that the compressed air pressure would still be 20....physics don't work that way my friend.If the idle pressure is 30#, the accumulator, with the pressure behind the piston is set at 20# will NOT empty itself of oil.
The engine side oil pressure HAS to drop to LESS than 20#, for the accumulator to work.
If the engine oil pressure stays ABOVE the air pressure in the air side of the accumulator, the accumulator will NEVER be able to push the oil out.
The accumulated oil HAS to overcome the pressure that the engine makes.
Your Pal, Gary
That's the entire point right there. If at rest you have 20 psi in the non oil side of the piston, then running, you will still have equal pressure on both sides of the piston. The oil volume will be less of course. If the pump pressure suddenly goes to 0, you have all that oil volume that will take time to be pushed into the engine. The pressure it is being fed with in this case will never drop below 20 until the supply of oil in the accumulator is exhausted. If you have 5 psi statics behind the piston, then there is virtually no pressure to push the last amount of oil into the engine. The point is probably moot anyhow, since the amount of oil that gets to the engine with enough pressure to go where it needs isn't all that much different in either case. I do run about 8 psi behind my piston, but I never run out of oil in the accumulator, so I really don't think it would hurt to put a bit more pressure in there. I don't think it would help anything greatly either.It takes "Time" Yeti master
TIME
That makes sense... But with the lower pre-load pressure, when the pressure drops to 20 psi.. You may still have a half quart of oil flowing out..The only benefit of running 20 psi that I can think of is in the event that the engine looses oil pressure and the accumulator expells oil in the engine the lowest oil pressure being expelled would not be any lower than 20 psi until it's empty but this would come at the exspense of having a lesser volume of oil to expell. Make any sense??
Bellman it makes no sense to run more than 7psi. All you need is enough pressure to keep the piston at the bottom of the accumulator when there is no oil pressure. Anything over that will result in loss of stored volume in the accumulator.That makes sense... But with the lower pre-load pressure, when the pressure drops to 20 psi.. You may still have a half quart of oil flowing out..
In all honesty, it comes down to personal preferences.. I like 7 psi cause with 9 1/2 quarts of oil and my accumulator fully charged.. My engine oil level is where I like it..
The reason I put the accumulator on in the first place.. Is because I have an oil pressure warning light that comes on at 25 psi.. And when I popped the chute at the finish line.. It would flicker..
Right here. We also use nitrogen instead of compressed air to avoid pressure changes with big swings in temperature.Doesn't anyone go by the 6psi Moroso recommends in their instructions.?
If you follow the instructions and run the piston to the bottom and then bleed the pressure back to 6psi then start the car what does the gauge on the accumulator read when you start the car? Does the pressure rise due to the compressing of the volume of air?
You’ve proven it takes longer to empty the larger amount of oil you have when you start with less initial pressure than it takes to empty the smaller amount of oil you have when you start with more initial pressure. Who would have thought?I finally got mine going Saturday afternoon. I filled the accumulator with 20 psi and opened the valve (electric) to make sure all the oil was out then bled it down back to 10 psi. When I started the motor I noticed that it did take away some of the oil pressure but just for only about 10 seconds. I figured that the valve really only holds pressure one way and will let oil pressure in even when closed. As soon as I opened the valve on the next start up the pressure bounced back up I guess due to the fact the oil pressure is being held up higher by the accumulator. So after letting the engine fill the accumulator I shut it down and then open the valve and see just how long it will take to empty. By watching the gauge and listening you can see and hear when the accumulator is empty. Mine made a bubbling noise as it emptied. It took about 37 seconds to empty. So now I put 20 psi in and do the same. Since my gauge has a 20 psi mark it will be easier to read. I open the valve and its empty in about 17 seconds. Not a scientific test by any means....lol. Also after letting it sit over night I lost all the pressure in the accumulator. Oh well....gotta figure that one out now.
The pressure reads exactly the same as the engine oil pressure. If it doesn’t, one (or both) of the two gauges is inaccurate.If you follow the instructions and run the piston to the bottom and then bleed the pressure back to 6psi then start the car what does the gauge on the accumulator read when you start the car? Does the pressure rise due to the compressing of the volume of air?
