93 Octane-What IAT to pull timing
3.8K views 7 replies 5 participants last post by  fa5t3r
Combo is aluminum headed SBC with S-480 at 15PSI air to air. IAT's rarely get above 140 degrees on a really hot day. I was running E-85 and set the ecu to start pulling extra timing out above 160 degrees for safety in case something were to go wrong.
Now that I converted back to pump 93, at what temp should I begin pulling extra timing out for safety and how aggressive should it pull back? The E-85 tune I had it pulling out a degree per every 10 degrees over 160.
#3 ·
I start knocking it back around 130 on pump gas setups personally... Logging knock sensors, I have seen a significant increase in detonation after about 135. This is on an LS3 with procharger. Every combo will be different but I tune a lot of boosted setups and have never had pulling at 130 cause a significant loss of power overall, nor have I hurt anything due to high temps. I usually knock 2 degrees out above 130, then starting pulling it more aggressively past low 140s
Best to gather as much data and read plugs when you can.
#6 ·
I dont how different those chambers are from 195 afr's but in general the afr line up out the box have pretty fast ports and quick burning chambers. My old setup was much more sensitive to timing than my current heads but also different cam so not apples to apples. I think 135 is a good safe start
#8 ·
Too many factors to consider. Just as an example, If you are running MBT timing at 77 degrees F, you should be pulling timing anywhere above that.
Engine temp is also a factor. you would run roughly 2 more degrees timing running a motor, tuned for MBT, by dropping ECT from 200 to 180.
Air temp wise, every 20 degrees is going to allow roughly another 1 to 1.5 degrees timing (or, more boost). But on the hot side of things, if you go from say 140 to 160, you may have to knock it back 4 degrees to prevent knock.
