275-60-15 drag radial on 10" wheel
1 reading
24K views 20 replies 19 participants last post by  0212roscoe
Question is, will a 275-60-15 drag radial work well on a 10" wheel or is a 10" wheel to wide?
#4 ·
I posted this question in M/T section and answer was 10" is best for 3754R tire. Hope this helps.
#8 ·
i think the 12 inch wheel pulls the sidewall the wrong way on a 275. i've run them on 8's and 10's and the car always worked better on the 10 inch wide wheel. the 10 inch wheel seems to make the sidewall straighter in relation to the edge of the tread and the sidewall seems to compress less on the launch
#9 ·
i ran 10's and have them on 12's now with no issue. 10's are the norm
#12 ·
I ran my 275/60-15's M/T's on 10 in. wheels. They looked "right" on a 10in. wheel.
My junk was slow compared to everyone elses stuff here but my drag radials hooked and worked better at 17-20psi. than they did down at 12-15psi. Small little burn out to clean the tires, not heat them up, shit and get.
#19 · (Edited)
275 Pro's on 10's on my Streetcar. Leaves on 12# boost 20# by 20' which is around 1100 to 1400 by 60' in car that weighs nearly 3800# 8.43:1 starting line ratio which is retarded for that power. No hi-tac, no bead locks slips the tires on the rims 4" average every pass. I'm going to try more boost, less SLR by leaving in 2nd and beadlocks to knock the 60' down into the low 1.20' from the current 1.28.
Google images "crusty nova" plenty of pics
