2006 duramax w/ allison 6 speed question
5.4K views 22 replies 9 participants last post by  vegaman924
Low mileage truck (about 85,000 miles) that pretty much only pulls the car trailer. About 16,000# rolling. Took it for a drive today to stretch its legs, as I haven't driven it much in the last 2 months. Its gotten very little use this year due to all the covid drama. Anyways, go for a drive, all is fine, but I start to notice the shift points are higher than normal, like its in tow haul mode, but its not........by the lite on the dash. I switch it into tow/haul mode and it shifts the same, so it appears, that even when TH is off, its on. All the shifts points are mostly above 2000 rpm, and it won't shift into 5th or 6th, until after 50mph and 2200rpm, which is exactly how it shifts when pulling. With no load, and TH off, it would normally be in 5th and cruising at 40 mph and shifting around 15-1800 rpm. The truck is clean and well maintained. I dropped the pan at 75,000 miles and change all the filters and refilled with transynd, and it has been trouble free, until today. Any ideas? Cross posted in Hutch's section as well.
#7 ·
Today's drive was without the trailer. I tried it in both TH mode and non TH mode, it shifted at the same points. It clearly is shifting at the higher shift points commanded by TH mode. The cel light is not on, but I will have my buddy that owns his own shop, and has an 04 duramax, scan it for me with his professional grade scanner to see what it shows. The fuel in the tank is about 2 months old, and I always run injector lubrication additives. I have a second tank in the box that I run algicide in, as that tank sits with fuel in it for longer periods of time, but I run the bio diesel additive shown in that tank. I've owned the truck for 6 years, and all I've done is regular maintenance (as described in my opening post) and the truck has never given me an issue. The batteries are not old, but the truck does sit for long periods of time. I will throw the charger on them and take it for a drive. The gauge on the dash shows its charging at 14V. The fuel filter was a new wix unit in the spring. The truck gets a new fuel filter every second oil change.
#3 ·
How does it pull at WOT?
If it's down on power it'll affect the shift points.
Diesel stuff that sits around can glow algae in the fuel. That'll plug your fuel filter.
I treat all my stuff usually once a year with some biocide treatment, it has the same active ingredient as antifungal creams.
The stuff is expensive, $25 a pint but you only need a little bit.
Here are a few other things to check
fuel pressure @ WOT , if you change the fuel filter cut it open and see if you find anything.
scan it for codes.
smoke check it for boost leaks
make sure the MAP sensor is clean and not sludged up
#9 ·
Those wix/napa fuel filters are junk, i've seen more problems with those and more fuel systems replaced with those plastic pos style filters. Stick with the white OEM ones or the parker/racor that's who made the OEM. Gm has a new blue filter that replaced the parker/racor I would shy away from that one to, they went cheap because the L5P has a diferent filter now.
#12 ·
Scanned the truck today. No light on the dash, but the scanner showed an engine temp code and a trans temp code. Typical diesel hates getting up to temp. Cleared the codes and ran it around the block. All back to normal. I will look at replacing to two sensors with new GM stuff. Thanks guys.
#16 · (Edited)
Don't waste your money.
I see a lot of high mileage trucks, I have a 7.3 right in now with close to 700k on it, I had a 2005 Cummins 5.9 here earlier this week with 475k on it, they made it that far without upgrading the stock filters. I've been around diesel trucks and equipment for 40 years and never seen a need to run any additives except biocide and anti-gel when they are obviously needed.
I'll add this: I have looked at some of these additives, I pulled their MSDS sheet and had my brother who has several degrees in chemistry and is a MIT Ph.D read them and tell me whats in it, it's alway the same answer from him, "a bunch of bs"
#23 ·
had algae in my RV when I got it 8.3 cummins was always changing filters full of black shit put the biocide in it and with in two tanks and two filter changes was all good it gets it twice a year weather I run it or not, cheap insurance and with every fill up one gallon of cheap two cycle oil ,get almost 2 more miles to the gallon
