I have a very strange problem with a self rebuilt 2004r. This trans has been working fine for many years and just recently, after a few hard and high rpm pulls it no longer shifts at low throttle and once it does shift it will fall out of gear when I slow down. I assumed TV valve issues so I dropped the valve body and removed the TV valve and checked all shift valves. Same issue, then I put a pressure gauge on it and found high line pressure at idle 150psi with no TV added, and it does rise if its pulled. I get a max of 240 to 260 in reverse. So now I assumed something was stuck in the regulator in the pump. Well I could not get the outer sleeve out of the pump, so I pulled the trans and actually went all though it and freshened the 3rd clutch pack and got the regulator valve out of the pump. Well the internal valve pieces seemed to move freely but the outer bushing that is held with the circlip has a very tight fit. I had an assumption that I did not fix my issue, and I was correct. Still 150psi at idle and automatic shift seem to happen at 5000 rpm. I'm kind of stuck at the moment, maybe someone could give me some ideas.
