Turbo 6.0 LQ4, TH400, with a masterpower 76, E85. The converter is not setup for the application and will not produce boost by foot braking alone(too loose down low). With the 2 step activated I can get approximately 5Psi @ 2900 rpm and 2 degrees of total timing. Heres my question….
I want to start messing about with rich / lean / low timing / lots of timing to get to my launch rpm quicker and hopefully get more boost on the 2 step. How do you know if its rich or lean while on the 2 step? The wideband can be all over the place, do you start adding / pulling fuel until it lays over and questimate?
Thank you,
Thank you,
