Bull if you put hardner I your paint wait a day you can wet sand and buff or just buff without any problems been doing it for years now it's a different story if you don't use hardner
First off, I'll try to ignore the lack of punctuation, and misspelled words in your run on sentence, and just give you how and why I have come up with my claims.
I have 43 years experience, started with lacquer, synthetic enamel, acrylic enamel, and polyurethane enamel. Used all the above in production collision shops, and used them in custom work as well. Over the past 20 or more years, it's been urethane single stage and base/clear systems, and now using water base as well.
This thread is about single stage blends, ...acrylic enamel was what I used exclusively during the 80s, worked very closely with the manufacturers paint reps, and it was my experience that told me I needed to lay down the best paint job I could, every time I painted something, because buffing that soft paint in any reasonable amount of time, was not going to result in an acceptable appearance. At that time there were high speed buffers (made for buffing hard lacquer paint) which would literally melt the acrylic enamel if used on it.
Perhaps acrylic enamels of today, that you may be using have changed but, to be honest I do not know one single painter or shop that still used acrylic enamel today, but I guess some hack, back yard garage shop might, or a used car salesman trying to polish turd might as well.
Single stage urethane paints on the other hand,
like I mentioned in my first reply, can be blended and buffed using the method I pointed out. Yes, of course it has hardener in it,....it's a catalyzed urethane paint, so whether it has hardener in it or not was never an issue. You need the hardener (activator) to have the paint chemically cure.
