what is the Bottle used when they Warm up Top Fuel Cars
11K views 39 replies 28 participants last post by  37688
What is the Bottle to the right of the Guys Leg? Co2 ?
I've seen these used when they warm up Nitro Cars....
#5 ·
Methanol to shut the motor off. The container is pressurized with methanol inside. You'll notice a quick coupler behind the hat that is plumed in to the top fuel distribution block. When you shut the motor down you turn off the fuel pump, connect the methanol to the coupler, and purge all Nitro from the fuel system and cylinders before killing the motor.
#19 ·
The team that I was with, we would squirt gas into the injector, then we had a pressurized bottle like that with methanol. We would run it on methanol to check for leaks, and set the timing, etc. Then switch to nitro, double check the timing (as the nitro hits harder so it can effect it), then seat the clutch and shut it off. Why use the $16.00 a gallon nitro if the $3.00 gallon methanol will work.
Brian
#27 ·
Brian
I am guessing this is the reason for the throttle blip ?
#25 ·
There is a different procedure for pit warm up and getting ready for run start. Some steps get omitted or shortened. Hand crank over backwards to clear cyls, spin over till oil pressure rises, stop, squirt meth in injector hat and have meth in pressurized jug plugged into quick connect to hat injector port, spin over while squirting meth in injector hat, pull ground to mag/s, engine start, stay on meth till hitting on all cyls, (in pits warm up this is when the timing is checked and leaks are looked for) push fuel lever to flow nitro from pump that is now primed and keep pressurized meth jug connected till all cyls are lit on nitro, undo meth from port, quick check of fuel pressure from pump and oil pressure up.....pull into water box and watch/listen for chief to give ok for burnout. There is a few variations and time on meth or gas (their choice) from teams but basically that is how it goes. Some teams warm up to certain engine temp first.
#28 ·
Nope, solid billet. Meth will keep it cool while running on it and the massive load of nitro and meth keeps it cool for a very short period then builds heat. Once heat builds it doesn't take long to get hot. That is why you don't see the old school burn down at staging any more.
#36 ·
Back in the Stone Age the 392 blocks often had so many sleeves in them that they were filled completely with Roc-Bloc. Some were filled to start with. Only the heads had water in them. If you look close at old pictures you can see the water necks on the front of the heads.
The cast iron 426 blocks and heads were more durable but still cracked eventually. Again look at old pictures and you will see the water necks on the front of the heads. We filled the block/heads to the bottom of the water neck. You will note also a small hard line from the water neck to the front exhaust pipes. This was just brake line. It allowed the steam to bleed off. By the end of a run there was not much water left if any in the block. We used a quick drain on the water drain on the bottom of the block to drain the remaining water. That was the first thing closed when we got back to the pits.
The first gen of KB blocks and heads were water capable. Basically the same as cast iron. I don’t remember which came,First, solid blocks or solid heads. Both about the same time. While they got hot they cooled quickly too. Thermo dynamics comes in here. Today the get really hot. That’s why everyone wears gloves.
Even alcohol motors get really hot as they are putting out so much power compared to what we used to have.
