What bbc bare block for 1500+hp nitrous build
1 reading
12K views 39 replies 13 participants last post by  mrdragster1970
Hi guys I was searching around here for the most affordable ways to make 1500+ n20 power. It seems like bbc is the best route? I've seen all kinds of different blocks/configurations but I cant seem to nail down the best block to start with. When I Google bare blocks there is different gens, deck hights, main options ect. Can someone point me in the right direction on the most affordable block to reach my goals? Thanks
#12 ·
To meet your goals will also depend on your budget. It was said to build a 5.0 BS block and ya, that's a great route to go but it will cost more to go that route. Like Darren said above, you can build a 632" using a Dart cast iron tall deck block and give it some juice and there you go.
#15 ·
He asked BEST to start with. 5.0 is much much better than any of the 4.84 stuff.
Most of us have so many pieces & parts we're kind of stuck until the thing splits in 1/2!!
I agree that a 5.0 block would be best BUT he did ask what was the most affordable and not what's the best... Pushing a 632 on a 4.84 iron block to 1500 HP wouldn't ever run the risk of splitting in half... Agree?
#16 ·
I missed that part.
Absolutely, my old Big M short deck better make way over 1500 and nothing special getting there.
Throw a used Big Chief on it, and 2 small stages and you're well over 1500.
#25 ·
Dart or Blueprint 632 are your two best options. Take the advice given above, you won't be sorry.
#28 ·
I cant find the m2 on summit, I normally try to go through them because I got a fat line of credit there lol. Using the search filter for cast iron 10.2 deck i can find 2 options. For 3200 I can get a big M mkIV cast full water block, or for 3700 they list a big M cast block. Im having trouble telling the difference between them . Would a full water block be weaker? Maybe the more expensive block is dry and reinforced better? The big M sportsman was considerably cheaper but they only list 9.8 deck even though the description claims 10.2 is available
#29 ·
Fastandloud87, I'm looking at doing the same thing you are. 632 and nitrous is a no brainer as far as economy goes. Call Beal Racing Engines and ask about their 632 pump gas motor. I'm changing out a lot of the standard options with mine and they're giving me a very good price. The blueprint engines 632 only puts out 820hp. Which leaves you a 700hp shot of nitrous to make up the difference. That's not a simple direct port system and at that nitrous level you're looking at nitrous specific cam, ring gap, plugs, and softening the chambers. 1500hp on race gas is a lot easier, building 1500 on pump gas is another story. Which are you doing? Sorry if I missed it.
I'm planning on a 632 pump gas that will make north of 1k hp and then spray another 4-600 on it depending on what's needed. Progressive controller, fuel injected, separate fuel system for the N2O, etc. I'm upgrading the heads to Brodix BB3s and running a solid roller instead of hyd. I'm not sure what heads come with the BP632 or if you're going pump gas, but the heads may be Liberty. Not the best. Consult with an engine builder, whoever you like. They will SAVE you money. For $15k it pays to have someone else as a consultant.
#30 ·
I'm not worried about pump gas, and im ok with using lots of spray. Im just looking to get enough power to hit my goals and not wear out or break the engine constantly in the process
#31 ·
I still need to find out if im gonna be able to fit that much engine in the truck and find a transmission to fit the bill aswell considering its a heavy vehicle and im sure that plays into trans capabilities. Its gonna take me a couple years to get both bought and assembled and in the truck but I like to have a plan. In the mean time I've been dumping money into building the rest of the truck.
#32 ·
I'm building a spare engine out of all my left over stuff, in case something happens to the 5.0 engine.
It's a 565" with used Big Chiefs, dual dom's and 2 stages, 32 each.
I'm hoping for 1550-1600 HP total, 1100 HP plus 600 spray should get me there??
It should be pretty low budget.
The most expense part is sending the intake to Steve to have the dual stages maximized!!!
#35 ·
Steel vs ductile caps is probably the main reason, also check the deck height.
#36 ·
I've had several 557-582" engines over the years and I just don't like them or the 632" on a 10.2 when spraying that much.
YES, I know there are a million of them the last 20 years, it's just my 2 cents!!!
That's why I'm converting my 582" with a single 32 stage to a 565" with 2 stages!!!
If starting from scratch and can't afford a 10.4 block, which would be hard to find used,
follow corcorans combo and find a decent 10.2 and build a 615" and spray the piss out of it with a much stronger, better designed piston!!!
#37 ·
I'm trying to take it all in thank you guys for all the info. Can anyone tell me if the Dart 10.2 full water mkIV will suit my needs? Here is a copy paste of item description. I dont need full water for any reason its just the cheapest Dart 10.2 I can find
Brand:Dart
Manufacturer's Part Number:31213655
Part Type:Engines, Bare Blocks
Product Line:Dart Big M Mark IV Big Block Chevy Full Water Cast Iron Bare Blocks
Summit Racing Part Number:DRT-31213655
Main Journal Type:454 mains
Engine Block Style:Aftermarket
Deck Height (in):10.200 in.
Cylinder Bore as Shipped:4.590 in.
Cylinder Bore Diameter:4.600 in.
Maximum Bore Diameter:4.600 in.
Engine Block Material:Cast iron
Engine Block Weight (lbs):280 lbs.
Main Bolt Style:4-bolt
Main Caps Included:Yes
Main Cap Material:Billet steel
Main Cap Fasteners Included:Yes
Main Bearings Included:No
Rear Main Seal Style:2-piece
Finished Cylinder Bores:No
Raised Cam Location:Yes
Cam Bearings Included:Yes
Freeze Plugs Included:Yes
Quantity:Sold individually.
Description: Dart is committed to producing the best engine components available, including the Dart Big M Mark IV big block Chevy full water cast iron bare blocks--engineered for applications where water between the bores is a requirement. Siamese bore versions are also available for larger bore applications.
Features of the Dart Big M Mark IV big blocks include:
  • Standard 9.800 in. and tall 10.200 in. deck heights available
  • Standard 4.250 in. or 4.600 in. bore sizes
  • MRK IV blocks use the 2-piece rear seal design, while Gen V and Gen VI blocks use a 1-piece seal and a different timing cover pattern
  • 4-bolt main bearing caps in ductile iron have splayed outer bolts for extra strength
  • True priority main oiling (lubricates the main bearings before the lifters)
  • Mechanical fuel pump boss, clutch linkage mounts, and side and front motor mounts simplify installation in chassis
  • Lifter valley bosses for OE style roller lifters and retainer; (Non-Siamese blocks only)
#38 ·
That will do it. ^^^
#40 ·
Since it's not a rush job to finish, why settle for anything.
Start looking for a decent 10.2 block, and take your time.
You might even get lucky & find a 10.4 from a guy stepping up to a 5.0.
You would definitely want the raised cam, big lifter bore, and the billet caps.
Hopefully something still close to 4.500 is best, unless you are going straight to a Big Chief, then 4.600 max,
not some worn out 4.625!!!
If the heads you end up with aren't drilled for the valley, definitely get that done!!!
