Vacupan (air pump) check valves and breathers
317 views 15 replies 7 participants last post by  bigblockmark
The early GM engines that used a A.I.R. pump (1970 and later) had check valves at the manifolds. It is what is used as part of the race car header/valve cover vacupan systems. Anyone got a part number that has a reasonable price that local parts stores can order? There were 2 sizes. The one that fits 5/8" hose and 1/2" female pipe thread is the one.
Also, the valve cover breathers that are used, part number?
#9 · (Edited)
Thanks guys. A 1/2" pipe nipple is $3 at Rural King. Cut it at a 45 degree angle and notch it and ready to weld in. Those do not usually need replacing. The check/backfire valve at OEM parts stores are probably cheaper than $30 if I can get a good number to work with. But counter guys and gals do not seem to find them in their computers.
The Echlin CRB 229000 is a 3/4' hose size. Most breathers hose size are 5/8". Need a number for the 5/8" hose check valve.
#15 ·
The breathers are 70's to 90's Chrysler items.
Early ones were black and a complete cylinder and the later ones were silver and stepped like the pic in post 2.
That's what we used in the day.
Mopar parts.
