Turbo 400 input shaft end play?
1 reading
22K views 20 replies 7 participants last post by  Shoedoos
Can you use turbo 350 pump shims to set the input shaft end play on a turbo 400 or does it have to be a thrust washer? It had a .095 thrust washer when I took it apart. I'm trying to get the end play set on my 400 and the selective washers that came in my kit are to thick. I was trying turbo 350 pump shims to see where I'm at and .020 puts it in spec to what the factory service manual calls for.
Thanks,
Eric
#4 ·
Sorry my post is a little confusing. I don't have selective washer at the bottom of the pump. It is just the turbo 350 .020 shim, so something is to tight. The forward drum is a 1 1/4" lower then the pump mounting surface like the manual says. I'm using the shims to see what I need for thickness and I don't know if there are selectives that thin?
Thanks, Eric
#7 ·
Make sure that you have your drums down all the way. I have seen where the builder does not get all the clutch plates aligned and the drum or clutch hub is hanging up on one of the frictions. Also make sure that you have your bearings facing the correct way and also the trust washers are greased into their proper locations. All of this will effect your end play and will be catastrophic if not done properly. Vince
#11 ·
Dragging this up from the past....TH350 torrington in the back, AXODE torrington on the clutch hub....I have .040 input endplay. Does this sound right? With the thinest foward endplay washer being .060 does that mean I need to remove .030 from the washer to get myself .010 clearance? Or is there a different method?
#18 ·
Adding that bearing changes the way front endplay is established. Originally the direct drum did not even have to be in the trans to affect front endplay and the thrust load was placed on the #22 bearing. Now that you have placed a bearing on the hub, the load is placed on a combination of the #22 and #21 bearing and the front endplay is reduced. Your now having to compensate for the addition of the bearing and alteration of thrust surfaces which allows a tighter endplay with the same given pump washer in place.
Hutch
