Hello there. This is a brand new Holley Keith Dorton 300-110 intake manifold for small block Chevy. I've read a lot of praise from reputable names, but never laid my hands on one before. I was intending to match and port, then try it on my small block with AFR 245NPP heads, or a future build with AFR 220 Comp heads. After examining port alignment, I've reconsidered. It will not work with my large port heads without fabrication including TIG welding and machining. I compared it to both AFR 6901 and Fel-Pro 1206 gaskets. I also bolted it onto the AFR 220's with the 6901 taped to the heads for reference.
