I purchased this valve body for my Turbo 400 about 5 years ago and never fitted it.
Now it's time to rebuild the trans. I'm not sure the valve body is suitable for my intended use.
The trans. shop I got it from is no longer around and I can't remember what I originally told them I wanted.
It's going behind a 500hp 383 small block which will be 99% street driven and see the drags about once or twice a year.
I'm rebuilding the trans. with the usual sprag, snap ring and dual feed upgrades and I want it to shift nice and crisp but not be harsh at part throttle.
The VB has the modified 1-2 shift valve and the vent hole plugged and the 2-3 accumulator is being held in place by an allen headed screw.
Also the holes for the 2-3 accumulator feed and reverse for the dual feed are blocked in the separator plate though it is only a single plate unlike the sandwiched Transgo plates.
I haven't yet tried to remove the screw to see if there's a spring in the accumulator ( I assume with the piston screwed down all the way and the feed blocked there won't be) or removed any of the other valves and checked the springs.
The 1-2 feed in the separator plate is .118" but my main concern is the size of the 2-3 feed which is .171" and another hole which is circled in the pic.has also been enlarged to .171" which the ATSG book says is the modulator feed.
I'd like some advice on whether I'm right in thinking this VB isn't going to suit my purpose and will make the trans. shift much too hard for what I'mlooking for and also if the other hole is the modulator feed and why it would have been enlarged ???
