I have to throw myself under the bus here to verify what I think is the solution so those of you that know better refrain from hitting me too hard. I have a couple street car builds I just wrapped up that are shift kit units. I used the transgo separator plate like I have in the past and put it on the run stand, well that's where my plan pretty much turned to shit. I put another one on there to check line pressure and it duplicated.... I got some regulator springs from Hutch so I have around 170-175 psi in all ranges except drive. Drive comes in about 130 with the modulator disconnected. When I hook up the modulator it drops very low, but I assume I'm really only concerned about the pressure disconnected as this would duplicate wide open throttle. My theory (and something I will be correcting today) is what everyone has always said and the transgo plate is causing a cross leak, thoughts?
