Starting line ratio
38K views 25 replies 15 participants last post by  fatwax
What's the best method to figure out what your SLR should be?
Also, how does it tie into your over all gearing for going through the traps?
Let's say the car is 2,800lbs with 900-950FWHP
Does it change with a radial vs a slick? If so how much?
3 speed automatic
Shift point of 8-8,500rpm
Full 1/4 mile
#2 ·
If you go to less or more rollout on the rear tires it changes the 'effective' rear gearing. The rear gear times your low gear is your "SLR". 3.14 Ă— tire diameter=rollout.
Yes SLR changes with tire diameter effectively.
#10 ·
Trap is more important then starting line when I pick the gear.
Unless you can spend the dough on a fancy trans, most of us run 1-1 high gear.
I did this test, with a 4.88 I had an awesome launch, but it was spinning too high at the end.
So I had to compromise so I didn't beat up the engine.
#12 ·
Way too many factors to give an accurate answer. Is it a 3 speed automatic or a 5 speed manual? Big tire with great track prep or a smaller tire with so so prep? Radial or a slick?
How wide is the engines power band? Its one of those things when you need to balance everything. In a 3 speed automatic you can usually only choose 1st and 2nd gear ratio, often they are locked together (cant mix and match) so you need to balance starting line ratio with shift drop rpm. In my experience engines with larger power curves are less sensitive to the 1-2 drop then narrow power band pieces. We still want as much SLR as we can get so we can get the car moving, but if we dont pay attention to what happens when we pull 2nd we can knock the wind out of the engine 2 seconds into the run.
This is one of the reasons a proflite is such a popular transmission for high end/high rpm combos, there are so many ratio options available compared to other lightweight low drag 3 speeds
#22 ·
TH-400's accelerate I'n 1st gear and when they shift into 2nd gear, they have to completely stop a drum and then accelerate it again in the opposite direction.
This is the "lag" on the 1-2 shift. This affected by your 1st gear ratio. You can have too much or too little first gear and make the transmission more inefficient.
I ran everything from 1.97 - 2.68 and always ended up going back to one ratio.
I wish I had all of that money back......
#24 ·
Calvin is really a nice talented guy, does nice work and can explain some things about headers that will make you scratch your head and wonder???? I was impressed with the fact that he started on monday morn and by 2pm one side compete, said pick the car up tomorrow after 3. Wed morn headed home. Fast, precision work. .
#25 ·
I've been told by a couple old school guy's that ran many years N/A before all these fancy new ratios came out. Put in more gear then the car will take, make the car work better to take it, and just let the bitch spin out the back door where it ends up. Also have been told that the car should be geared to the 1,000' as well when racing in the 1/4?
