Star is very good quality. Sportsman pump is cheaper, Standard is for use with power adders and such. I like the regulator mounting right at the pump. Does not pull in outside air into the engine. I had one truck pull engine that had 1/2" of oily dirt in bottom of pan, that had the regulator on valve cover. put regulator at pump and next time I saw it, nothing foreign in the bottom of the pan.
