I installed the sonnax boost valve in my th400 today. I noticed the boost valve was very tight in the "sleeve". It took a light tap to knock the boost valve in, boost valve moves a slight amount freely (~1/8 inch) but will catch and cannot be removed by hand without a tap on the back side. Do i need to order a new kit or am i ok? Also, about how much travel does the boost valve need to actuate the pressure relief valve?
