I bought a 454 to 468, BALANCED, rotating assembly from him/them a few years ago; then had MY machinist go through ALL of it. Only one rod had been removed from the plastic covering it; same with the pistons, and the crank had't been touched by human hands since it was packed. So, they used STOCK factory balance weights, to "ballpark" the so-called precision balance I thought I paid for. MY machinist did do a PRECISION BALANCE, which is what I thought I was paying for. Will I do business with them again? Absolutely NO!!!!!!!!!!! My short block is together, everything looks good, and the heads are sitting on the shelf, ready to go onto the short block. I still think it was a cheaper way to go, even though they were not completely TRUTHFUL, on what they did. Will I do business with them again? NO WAY IN G.D., F'n, HELL!!!!! NO ONE lies to me in a business transaction, and gets away with it. When my car finally hits the track, just see what the decals say about, "Skip White"; it ain't good. You listening Skippy Boy? I got what I paid for, I knew there would be some, "iffiness", in dealing with them; I took the chance, and wisely had the parts re-balanced, and should be fine, now. I won't send ANY repeat business their way, NO referrals, and that's what's really important in ANY business, repeat customers and referrals. Now, I spoke with "Skip White or his representatives" on the phone, before AND after, the arrival of my parts. And I knew there was some "piling up of the fertilizer pile" going on, but I did NOT expect this much DECEIT. Straight out LIES about how they "balance" a rotating assembly. Like I said, my machinist went through everything, and I trust him completely with his work. Everything, should be fine, NOW. The crank also had to be polished, so it would't literally destroy the bearings on startup. ALL the rods had to be re-balanced, big and little ends. Pistons/pins had to be weight balanced/matched. Major brand bearings and rings, so that's pretty much a given with balancing. And yes, the crankshaft had to be PRECISION BALANCED to the rods/pistons/bearings, and rings. Was there a cheaper way of going about ALL of this? Yes, but it would have involved using the stock, cast crank and rods, maybe some aftermarket pistons, new rings/bearings, and all of this may have cost me more in the end; in the "long run", as they say. Time will tell just how much of ALL of this will work out. Hopefully, my little big block, will leave it's mark on a few competitors, and not on the tracks surface. There is ALWAYS some trade-off when dealing with these cut-rate vendors; I overestimated just how much Skip White was playing with. I am Butch/56sedandelivery.
