I'm planning on using yellow wire to activate shifnoid.... how much earlier should i program it than actual desired shift point? Someone said 400 early on 1-2 adjust and 200 early on 2-3 shift... thoughts? 1400hp nitrous car th400. Ty
What is the max amps the grid yellow wire can handle? Does it have a fly back diode / surge suppression?
I've researched the shifnoid on my car and it is really a 1980's Bosch starter solenoid ( the older removable cap type ) repurposed as a shifter pusher. ( Power glide so only one push )
Mine has the pull in and hold in windings in parallel so they are going to have a high current draw and should not be left on for more than a few seconds. ( In a starter application, the pull in winding drops out when the starter is engaged )
I'd run a relay with a fly back diode / surge suppression across the shifnoid positive and ground. The relay will have some delay in triggering and the shifnoid / shifter movement so that that into account.
Yep , and in theory, the orientation of the relay can have an effect on the delay. If the movable contact is facing forward, acceleration can reduce the delay. If facing rearward, increase the delay. If the movable contact is facing up or down, really bad tire shake might chatter a relay?
The only way to be sure is look at a data log and go from there. But even then, not enough sample rate can skew data. I'd say set it up to shift somewhat early then look at data.
I use a toggle switch on mine so the load is only on after I am ready to stage.
It's a pain holding it in first, but it gets too damn hot leaving it energized.
I also use two relays in series just in case.
I had one fail before.
Load in series, trigger in parallel.
Related Threads
Yellow Bullet Forums
posts
24M
members
152K
Since
2005
