well guys, been going crazy trying to figure out my ignition setup, motor is sbf dart 427, holley hp efi, innovators west crank trigger, 64bit tuning cam sync, gm truck coil packs. holley universal coil on plug harness. have injectors 1234 pass bank 5678 drivers, coils same. ford ho firing order 13726548. car will not start .
so I re-pin coils to 2468 pass and 1357 drivers, change firing order to gm ls 18726543, car starts right up.
whats the deal here? anyone else have this issue? should I re-pin injectors to match? also should I use the drivers front cylinder to check timing now that its #1
