SBC STUD GIRDLES
1 reading
12K views 28 replies 13 participants last post by  slow8.0
I have a 427" sb with Motown 220 aluminum heads and 7/16 studs. Are stud girdles worth the effort? I had a set on my last motor and it seemed that when I tightened them up it threw off my valve lash. That was on a old cast iron headed motor. would I benefit from them on my new motor?
#6 ·
Jomar. The original maker of stud girdles. Call them for correct part number for your heads. Good people to deal with. Girdles and nuts are 2 separate numbers. Need to know what your rocker arm size is where the nuts meet the rocker trunnion. .500", .560", .600". (Whatever you polylock diameter is.) Then you can look for a dealer and see if price is cheaper.
#15 ·
who said they were ever worried about what they are spending on anything? not me.. I have over 12 k into the motor already and honestly don't think It will be finished. I did say I was surprised that the Jomar bars were cheeper than most other brands and was surprised as they are what most recommend.
#16 ·
I believe they are required. I had a set of Iron Bowties with 7/16th studs and with 140 on the seat and 350 open without the stud girdle it would deflect the top of the studs .003" just rolling it over by hand. Crane Gold Endurance Wide body 1.5 rockers. If installing the girdle changes your lash something is way out of line or flexing terribly. With my 8500 rpm 867 engine with 250/600 it didn't change my lash not one bit installing a girdle. What will change your lash is tightening the set screws too tight. Get a 3/8 drive torque wrench to add some consistency to your settings. Follow the manufacturer instructions for torque specs. When running the valves I never break the girdle loose unless something needs moved which it they start moving indicates something going away. Another big mistake is over tightening the girdle bar bolts. 25-30 foot pounds max for the aluminum threads. Going more than that and you could see them bend.
World Products recommends Part # 832005
http://www.theengineshop.com/product_images/product_pdf-pdf_file-157.pdf
#19 ·
It doesn't make sense a girdle would affect the clearance on the lash. At lash there is no tension on the stud so when the girdle is installed it must be pulling the stud one way or the other.
Were these double bar girdles or single with U bolts? Did the bars slide on real easy or did it require some effort to get them on with the bolts only backed out minimally?
Did you ever put an indicator on the assembly to see what was moving?
I did and the girdle and stud on the .705" lift roller still moved a little but in the range of half a thousandths (<.0005") or less out at the ends. The only measurable affect should be a slight increase the net valve lift due to less stud deflection.
So they are moving did it change the lash evenly or were some different amounts?
Not trying to be smart but you got me interested on how this could be.
#20 ·
Im not trying to be a smart ass either, I truly try to learn everyday. In the 70's, when Jomar, I believe were the first girdles out, and this all pertains to the small block Chevy. The one with U bolts I used on 3/8th studs, and they would have to be set again after installation. They move up, down, left, or right enough to change the setting. I can't go through every scenario, but let it be said that I've seen girdles installed on almost every style 23 degree head from several big named engine builders, all later with 7/16ths studs and I have yet to see one that would stay perfect after setting the valves, and then installing the girdle. All in the last 30 years have been double bar girdles. I watched one guy set them, then install the girdle, and I asked him if he'd let me check. He did, and some were .030 off. Just went and set an econo mod pulling tractor done the same way, and only One was right on. Just relaying what I've found. If yours stay perfect, great. The ones I've done do not.
#22 ·
Does this make sense to you or didn't you ever think something was up? Do you have a theory as to why a girdle would be changing lash?
Which method do you use to set lash? Are you setting lash on both valves at TDC every 90 degrees in the firing order or are you using, set the intake when exhaust is opening and exhaust when intake is closing? And then the guys you double checked on? This sounds more like they are not fully on the back of the lobe and are catching a ramp.
Shawn
#23 ·
Intake when exhaust is opening, and exhaust when intake is closing. But I check both in three steps. Such as intake when exhaust is opening, then a touch further, and a small bump further. There is a sweet spot when maximum clearance is obtained, and this rule is just a good start. How the others checked I have zero idea. In my opinion, no stud girdle, or al least none I've dealt with are machined to not pull on the studs a little one way, or another. Once set, they will stay almost as good as a shaft setup. But are much more trouble. Just my experience.
