How much does mild steel tubing weight per foot vs chrome moly? Thanks
If it is the same wall thickness the moly would be heavier due to the density of it. For roll cages you can use .083 moly instead of .134. Our 1-5/8" x .134 erw weighs 2.05lbs per foot. The 1-5/8" x .083 moly is 1.47lbs per foot.
The SAME outside diameter1 5/8 and same wall thickness
Whoopi Fucking Do,......But the value of a car with a Molly roll bar/cage is higher.
NEVER,.......is a strong word.I Would never buy anything with a mild steel in it
OH No I ment "never"!Copper head;4182**** said:Whoopi Fucking Do,......
Who gives a Rats Ass,.... unless you plan on going faster than 7.50's.
If 50lbs of extra weight (due to a M/S cage rather than C/M) is a deal breaker for you,......then you would probably be missing out :roll:
