Well, I could probably write a book on this topic alone. We are learning more and more about the tire to wheel relationship every day. (This is true even in Top Fuel) It wasn't that long ago we did not suggest going wider than 1" on rim width past the tread.
We make recommendations based on the performance of the vehicle and trying to optimize the performance of the tire. I'm always one for suggesting the smallest tire that will get the job done, therefore, the tire and wheel combination should be put together to get the most out of it. Running the proper wheel width does several things.
- Optimizes the footprint of the tire at the proper inflation for better traction.
- Enables the sidewalls of the tire to perform as designed.
- Reduces the chances of tire shake by helping the tire "stay round" and improving control of the tire itself.
- Improves tread wear - the tires will last longer.
- Enables the tire to carry more "load" at a given air pressure.
Yes, changing rim width will effect the section width of the tire approx. .400" for every 1" change in rim width.
I hope this helps some. Again there are many theories and designs behind this, so I did my best to provide a high level overview.
Thanks,
Jason Moulton
