What material would you use to run gas lines in the house from the propane tank?
I've seen copper, plastic, and black screw pipe.
Screw pipe is a pain in the ass if you dont have a threading machine which I dont have.
If copper would you do sweat fittings or compression?
I'm trying to get this stuff all piped in in the next couple days and I'm not sure what's acceptable practice. i live in the middle of nowhere so there is no code i have to adhere to. I will pressure test it for 24 hours to check for leaks.
