Hey Everybody,
What simple or cheap mods help 1994 454 C2500 with towing?
Thanks, CraigG.
Thanks, CraigG.
It's very easy to get that TB opened up a bit and bushings installed. Forget about the supplied Edelbrock chip and have it tuned properly- or as mentioned a proper ecu with good drivers. I had this system years ago on a vortec 350- wish I knew about tuning then....it's a good EFI.I'm following with much interest, because I'd like to build something similar for my '89 TBI truck. I have a nearly new Edelbrock MPFI setup, would that flow enough air with the TBI throttle body to feed a 496 to 4000 rpm for towing? Using the MPFI deal would allow use of the OE computer which could save a lot of work or $. It has the larger injectors intended for use with a 502, that's why I have it, it didn't work right on a 454.
I have 2 sets of heads on hand, a pair of 3989241 and a set of Truck 3983136 castings. Both oval port, the truck heads are sort of closed chamber, CCs unknown ATM. Would either of these be a good choice?
Would the MPFI small port manifold work OK with oval port heads? If not, would a larger oval port manifold with bungs for the injectors work with the TBI TB or would a larger TB be needed?
I have a NOS set of Doug Thorley long tube Tri-Y headers for the truck - single outlet for the cat.
dynamic efi is nice setupFor my 89 truck with 7747, Edelbrock ran 4/4 injectors, my only problem was poor splicing but I heard others had driver problems. DynamicEFI makes a pnp 7747 among others that is specially modified with a 'port' mod, been runningit for years with several sets of different injectors- my tuning skills are crap however.
I'm looking for simple inexpensive and effective. NOT trick, not cool, not high tech, not to impress anyone. Use available parts if possible.Yoyodyne:
Not sure what you are thinking here but you need to get back to a better starting idea.
Here are the casting numbers with a corresponding chambers, what do you make of them?First none of those BBC head casting numbers are correct?
To go 496 I need to buy pistons anyway, why not buy the pistons I need to get the correct compression with whatever heads I use?Second if you are going to spend that much money and trouble trying to put an old technology "Edelbrick" semi -efi system and remain with a stripped down TBI throttle body only you are wasting money and not getting any real towing "bang for your buck"!
I would not put any money in to old iron BBC truck heads done right when you can buy a nice set of new or completely reworked Vortec small chamber heads for less than you will put making an old set of truck heads work! They add compression WHICH YOUR 89 454 TBI NEEDS BADLY!
I already own all the stuff I described except for a crank and pistons. I'll also need a cam regardless. I think new AL heads fit that big dollars category.The headers would be a nice addition since you already own them.
All I can say if you're a wise man and want to make an older 1989 TBI truck work for TOWING, keep it simple, follow something like I laid out on this post and don't try to get torque and towing performance putting all sorts of big dollars into expensive EFI systems and engine conversions and builds, when the cost of these types of conversion would probably exceed the value of the truck.
JMEXPO![]()
Yeah, the "let's do a whole alum topend" on the $5000 truck is great idea, but just not worth it $$$ per hp gained. Bang for buck, E-brock tbi intake, home port it, find a big bore TBI for it(there used to be shop that made super big ones, but I think they shutdown), chip it/tune it and 3in single exhaust w/ good plug wires. Done. The headers will drive you out of your mind w/ exhaust leaks, even with good gaskets. If there is a set of higher ratio bolt on rockers, do those too. IMO pulling the heads off is a waste of time unless you absolutely love the truck. If you do really love it, a Cummin's or Vortec swap is best $$$ spent long term
Ok, I did not realize you were building a whole motor, thought this was just an upgrade deal. If you are building, just go as cheap as possible. Everyone is going to tell me I'm wrong, but I would just pocket port the stock peanut heads, shave them .020, put the cheapest-cheap shit cast pistons in it. Find a thin head gasket for it, something in the .020-030 range. Comp makes a TBI Cam or at least used to, call them. IMO doing alum heads on any TBI motor is a complete waste. I remember a 454SS that a friend of mine worked on back in the late 90's. Had ported aftermarket heads, a Whipple blower, cam, you name it....and a stock TBI strapped on the back of the blower. Was always slow for what it was. He sold the truck and the next guy put a carb on it and went like 2 seconds faster, lol. TBI= don't waste money on it.Dave gets it. I'm not building a hot rod. I need a new motor, this one leaks more than it burns. I can do a crate 502 or do a 496 for slightly more than the cost of a rebuild and use up some the the parts I already have. If I can get another 80 - 100,000 miles out of it reasonable cheaply then either I'll buy a diesel Megacab or I won't need one at that time.
The truck already has a Edelbrock TBI intake manifold (only because the stock iron manifold cracked) a 3" exhaust and other than the worn out motor it suits me just fine. Doing a Cummins swap to my satisfaction would cost more than doing this motor and I really don't want a diesel. i don't want a Vortec or a 8.1 because I don't want to have to take the truck back home to the shop where it was built when something fails along the interstate.
Do you have a recommendation for a cam from someone other than CC? Or this cam with other lifters?A good towing spec. cam for this use is a Comp Cams part #11-412-8 grind # 266HR-12.Available from various suppliers for about $275 -300 per cam.
This cam will produce the most torque between 1500-3800 rpms which is where you want it for towing. With this cam you will be able to tow in many areas in OVERDRIVE between 55-70mph! This is ideal for towing and mileage!
Use any hyd. lifter you want to with it. Don't feel restricted to having to use all Comp components. If you want something custom and "a little more" I can spec a Bullet or Cam Motion cam for you. General rules of TBI are stay close to factory intake duration, run as much lift as you can get away with cheaply, run as much exhaust duration as necessary to make some power and keep the chamber a little cooler at cruising speed and keep the lsa 114 or more, or at least have no overlap. RRay recommended some good ones, also, but I do not recommend the Elgin w/ the 112 lsa. TBI needs a super strong vacuum signal to function right. Not worth the possible driveability loss for the power difference.Or just use this cam with other lifters?
I'd just buy a crate 502 and the Edelbrock intaoe should fit, call me or someone else who can do a chip, upgrade the fuel pump and enjoyDave gets it. I'm not building a hot rod. I need a new motor, this one leaks more than it burns. I can do a crate 502 or do a 496 for slightly more than the cost of a rebuild and use up some the the parts I already have. If I can get another 80 - 100,000 miles out of it reasonable cheaply then either I'll buy a diesel Megacab or I won't need one at that time.
How does the cam in the HT502 compare to the cams listed above?I'd just buy a crate 502 and the Edelbrock intaoe should fit, call me or someone else who can do a chip, upgrade the fuel pump and enjoy
The HT cam is I204/E209....... I.480/E.483 112lsaHow does the cam in the HT502 compare to the cams listed above?
Flat torque curve to 3600 and starts to roll off after 3600.
IIRC HP peak is at 4200.
Pretty wimpy cam and you could likely pick up a bunch with something
better as long as you have a way to tune the ecm.
