Port work on Blue Print 357cc BBC heads
1 reading
3.3K views 44 replies 12 participants last post by  374coupe
I came across a set of these heads brand new from a guy set up with solid roller springs with Ti retainers at a price I couldn't pass up. May throw them on a street 565 in a year or two after I retire. I took some measurements and thought i would share the info.
Intake 358cc 2.30 11/32 stem Exhaust 125cc 1.88 11/32 stem
Bowl width 2.365 102.9% Raised .300 D shaped
Throat 2.037-88.6%
Short side width just before the turn 2.155
Short turn height 2.030
Short turn area CSA 4.37
Push rod pinch width 1.609
Height 2.412
CSA 3.88
Deck looks to be around 3/4" thick
Combustion chamber 119 cc
Advertised flow on Blue Prints website, could not find any flow numbers listed higher then .600
Int. Ex
.100-116 seems high? .100-84
.200-184 .200-130
.300-241 .300-183
.400-291 .400-226
.500-328 .500-260
.600-351 .600-286
I have no idea what head they may be copied after or if it is Blue Prints own deal but they seam to have a modern style chamber like AFR, the short turn and the bowl look to be pretty good.
What do you guys think? Could this head possibly be made to flow over 400 cfm and make good power?
#2 ·
The head is more than likely not set up for any more the .600 lift or the flow just drops off at that lift, DK, but if they do flow 350 cfm that's good for 700 hp or so, kind depends on you. But with some of this type of head you better have a good head guy look them over real good as the machining might not be spot on, I would go to Jegs or Summit or any other place that have sold this head and read the reviews if you can't find anyone on here to clue you in.
#5 ·
There is nice size ridge right after the top cut on the intake and on the exhaust which would affect the low lift numbers more? Could the throat only being 88.6% start affecting the higher lift flow? I'm still learning and i'm sure the heads have more potential with a good valve job, blending the ridge in the chamber and a bigger throat.
#6 ·
I would get on this guys channel and check out all his BBC head and intake videos, he has some good do's and don't on porting and valve jobs videos too. I think he also has one video on what to check on china head castings. If you haven't already I think it would be worth your time.
#8 ·
I started doing some work on these Blue Print 357 CC BBC heads. The heads look like they have really good castings and are a spitting image of the AFR 357 head with some minor slight differences. So far the intakes now are 372 cc's, exhaust 131 cc's with stems, chambers are smaller than i thought and came out to 117.3 cc's after some mild chamber work with 2.30-1.88 valves. I set the pushrod pinch at 4.2 CSA, the bowl width now is 2.400" about 104% of 2.30 valve. Now I'm by no means any professional head porter and just trying to learn as much as I can by reading and watching some videos from guys like Chad Speier, Eric W, Darren and others which has been really helpful. I'm fixing to retire and will possibly be putting these on a 582 with normal bracket motor type/ limited street use solid roller, 2927 intake, dominator turning around 7000-7200 RPM's if they come out good possibly trying to making 900 HP with these heads at only 11:1 compression. The couple questions I have is what a good CSA would be to start with for a set up like this right before the short turn apex and also would be going to a 2.35" valve be a big improvement for power over the 2.30". The issue now is I don't think I have enough seat width for a 2.35 without replacing the seat which would be more dollars. Once done I will send the heads to someone to put in a good valve job, set the throat and have them flowed and check some air speeds. Any help or tips with this head project is appreciated!!
#9 ·
BBF612, I watch some of Eric's videos and find a lot of contradictory info then what is out there, like the SBc Vic Jr seems to be the best usually from him, yet the other porters put it around 5 or 6th place. He also he seems to really play-up the ProMaxx heads, that he even said they used his services for the Project X Sbc heads, and down plays the Flotek heads. Yet on my personal Flotek BBc 290's and SBc 220, our info was quite different than what he advertises and says.
I bought my 290's and the seller actually took $$$ off and through in a free valve job to keep me from going with Eric due to issues he has had and heard. BUT that was like 5 years ago, so maybe he has changed?
#10 ·
This is an old thread, but you can provide all the information you can to help the OP.
#12 ·
May not compare, but when Dart does the Pro1 CNC 365 heads, with the 2.350" intake valves, the exhaust valve size is 1.850". I have used a couple sets of those. I cut down Manley Severe Duty 1.880" exhaust valves to fit. If you look at the Dart flow sheets, the 345, 355, 365 really don't gain that much intake flow between them, except over 700" lift. Still better over any Brodix BB2 head by 40 CFM, including the 325,365 Dragon Slayer, which I like for the money and availability.
#15 ·
I don't know what they flow, but a buddy has a Blueprint 632 in his full weight, show car looking 1971 Chevelle. It has a TH400 and 3.70 gear.
Naturally aspirated, it ran 9.98 in the 1/4, and on a 200hp shot it ran 9.10. In the 1/8 it ran 5.80 @ 121.
It was running out of gear in the 1/4 mile, so it was only going low-mid 140's on the bottle. I don't remember the n/a mph.
He bought it several years ago (pre covid) for around 12k turn key, carb to pan. It hasn't had a valve cover off of it, runs on pump gas n/a, and has exceeded expectations. You can drive it on a 2hr round trip if you want to buy the gas for it, and never have an issue.
I'm assuming it has the heads mentioned in this post. I don't know what they flow, but they obviously seem to be working quite well.
The engine has diesel torque and doesn't need revved to the moon to run hard. He will spin it right up to 7k rpm trying to make it to the end of the 1/4 on his 200 shot, but normally shifts it around 6500. He accidentally took off in 2nd gear one run, and it was only 0.1 seconds off. lol
He recently updated the $300 Jegs converter, so it will probably be quicker now, and not run out of gear like it did.
The heads are obviously quite adequate... and the engine has a 3yr/36k mile warranty.
Once he does decide to freshen it up (no signs of needing it now, but he may do it anyway to check the ring gap for more nitrous) he may be interested in getting the heads ported, if someone is familiar with them, or has a good program.
#16 ·
The heads were talking about are the PS8012 358cc’s, they also make a smaller 315or 320 cc head. I found where someone did some work on those and got them to go a little over 400 cfm. Like I said before there very close to the AFR 357 and when I had a chance to pick these up for $1000 brand new from a boat racer I grabbed them. There probably a little on the small side for the 632 crate motor they come on so any work you do to improve flow will certainly help. Just doing a good valve job, open the throats up, blend everything in and open the push rod area a little I think would see good HP gains maybe 30-40 HP on his 632 since it’s already head limited. A full blown port job by some of of top guys like Foxwell, Chad and many others on this site I’m sure would see some excellent gains. Definitely a head not to overlook if you come across a set for a good price, most people would probably just over look them since there not a top name brand head.
#17 ·
They need a bigger valve for a 632 unless it's an RV engine or in a 4x4. That'll probably give you the most bang for the buck. You can port them till the cows come home but airspeed through the valve will be too high, hurt VE. A bigger valve will give you more area and more volume. A 632 eats up induction real fast.
Appreciate the mention.
JMO
#18 ·
Throat 2.037-88.6%
Height 2.412
CSA 3.88
Int. Ex
.200-184 .200-130
.300-241 .300-183
.400-291 .400-226
.500-328 .500-260
.600-351 .600-286
That head was copied off a Brodix BB-2. Then BP made minor changes to avoid legal matters.
#20 ·
I’m going to guess Blueprint can assemble them and maybe use them across multiple engines, and all the ancillary stuff / time of assembly is within what they already have.
They do tens of millions in business, so no doubt it’s profit driven.
#25 ·
I'm a big fan of Blueprint. I've never purchased one of their engines, but many of my Chevy friends have.
All were purchased pre-Covid, and were ridiculously inexpensive, especially compared to today's prices. You couldn't come come close to building the same engine for the price of parts alone at the time. There was only one failure, a 489 BBC. This was the first BP engine anyone from around here bought. It had what sounded like a rod bearing go out. BP was called, and they said to leave it as-is, and they would send a replacement. They only wanted the long block back, and sent a replacement that had more on it than the longblock did. It's been running strong ever since. It's crazy they come with a 3 yr/36k mile warranty. All are pump gas friendly.
396 SBC. Carb to pan was around $5k, I believe. Installed in a 3rd gen Camaro and ran 7.10 right off the bat. Zero issues.
Two 489 BBC. One is in a full size square body truck that is very heavy. Runs 7.20's with a 70+ year old man driving. The other is in his son's 1970 Nova and ran 5.95 on a small to moderate shot of nitrous. I think it was jetted for 200hp.
632 BBC. This is in a full weight Chevelle. Has run 9.9 in the 1/4 n/a, and 9.10 on a 200 shot blowing through the converter at 7k rpm at 144 mph with a 3.70 gear. Ran 5.80 in the 1/8.
He paid $12k carb to pan. Made 830hp on his dyno sheet, which is easily believable. This is with a mild HR cam designed to last through a 36k mile warranty on pump gas. I don't know anything specific about the engine, other than it has the torque of a diesel and hauls ass. You could literally put almost any converter and gear in the thing, and it just wouldn't car. He accidentally launched in 2nd gear (TH400) and only lost a tenth. lol He wants to go to a 3.55 gear in his Dana 60. I've spent a lot more and worked a lot harder on my 363, and he just pulls out of the garage and hauls ass... and has been doing so for probably close to 10 years without ever pulling a valve cover. lol Same fully dressed engine now is around $17-$18k, I believe.
For someone who wants a crate engine that runs GOOD and has a solid warranty, they can't be beat.
I don't know what the heads flow, but the engine is making 830hp with a lazy camshaft that is normally shifted at 6500 rpm.
They're doing something right. I wouldn't hesitate to use BP parts.
When developing combos, they use dyno mules to try different parts/cams/etc on and do long term power and stress tests until they have a strong, reliable combo. Once they have tested and tested to find what works, it becomes their crate engine combo. All the guesswork has been done.
Most of us here always want MORE, so they aren't usually for us, but for the general population, are a fantastic option.
The heads, parts, blocks are well tested.
#24 · (Edited)
Blue print head is not the same as the BB-2, the BB-2 is 26 degree valve angle the BP head is 24 degree. The combustion chamber on the BB-2 uses an older style chamber similar to the factory iron 990 or 188 chamber that has less quench pad between the valves on the intake manifold side and more shrouded on the spark plug side, totally different chambers. the BB-2 exhaust port is raised higher .500-.600" the BP are raised .300". I had the heads side by side with a AFR 357 and they are very close to each other which is one of the reasons i picked them up. Now whether they can be made to flow good air or have the same power potential that's different story.
#26 ·
I have a customer that recently bought a Blueprint replacement SBC 383 engine for an air boat. Local machine shops could not meet his timetable to get the boat on the water. Blue Print did. He went to Nebraska and picked it up. They even gave him a slight discount for being a veteran. But no warranty because it is in a boat. Prop speed is limited to 4200 RPM and it is direct drive. Salesman said if he had any engine issue to be sure to call him back personally and he would be of assistance. Engine runs very good.
#31 ·
From what I know and what I have, Blueprint seemed to go above and beyond with their stuff.
I have an older Blueprint 632 I bought used off a local truck guy. He had 3 he got all at the same time. The old stuff, that I presume Blueprint copied was top shelf stuff, at least my 632 short block is.
Mine has a broke ring land in 1 piston. From the serial number on the block, it has JE pistons, Oliver steel rods, and K1 crank in Blueprint block.
The heads of mine were a lot different and as well as the alum single plane. Coil-on-plug and has newer hyd roller lifters with the spyder hold down.
So I would suspect that with some minor head work valve job and a came, these 633 will make over 900. I think Blueprint just detunes them for the warranty and these 830Hp 632 will still run when set up right. Other builders use better heads but most of their hyd 632 are under 900 too, like SSRE with CNC ported BB3 380S.
#33 ·
Ya I think some probably are. I was looking at a Scott Schafrof ultra street 632. I think there was a guy with one on here that had a thread about 8 second streetcars. SSRE hyd 632 is 895Hp I think.
Now you can not compare these BP 357 heads to the SSRE Brodix BB3 CNC 380's. The 380s are MILES ahead of the 357.
I'm sure these heads can be reworked to make very good power and flow. But a 357cc head is better suited for 540/555 size engine, like the OP us planning. Certainly no reason these can't blow right past 420cfm.
#36 ·
Those heads are way too big for a 10:1 540 like that (@ NPS Nova).
About that same time I had a customer that I built a set of AFR 315's and a ported Vic Jr that went on his 540. It made 770 on pump gas with a 1000cfm 4150 and hyd roller. That was on Rick Waters dyno in AZ.
#35 ·
#37 ·
Scott, MY 478 pump gas went 9.01 N/A with BMF 350 heads through the mufflers @ 3250+ and UNDER 10-1 comp is a full street '68 Nova at the WORLD STREET RACE IN BELLE ROSE, LA. MY 509 has made just over 940Hp with BB3 CNC 380's OOTB been high 7's on nitrous in 3600+ 10" tire grudge street car. BUT we have also did a 509 pump gas with BBO ported and OEM GM intake and made 770Hp+ in full weight '68 Camaro with a 5sp. I also seen a bunch of 540/555 with AFR 357 running well at the track, mid 8's NA. The 460 that beat the BES "shop truck" of Jim Huber in "SUPER MODIFIED CLASS racing in NMCA", then lowered the class record by more than 2 tenths, used a 470+cc head.
But I will say that Blueprint 540 that BBF posted is weak, but think it's more about longevity that outright power. And for that style of 540 motor the 357 are big.
#38 ·
When looking at different heads port cc's, they only tell me something if the heads have the same port center line length. 2 heads with the same average CSA with different port center line lengths will have different port volumes.
Stan
#39 ·
Advertised CC's really say nothing about the port, even with the same port c/l lengths. It doesn't say anything about where the volume of the port is. Old school BB Chev ports and even some today have a lot of volume in the front of the port with big openings and very little bowl volume. Other ports have less volume in the port entry and more in the bowl and short turn area. Those two different ports, with the same c/l distance and same advertised volume will behave entirely different on a same given engine. I have a 351cc BB Chev port in an AFR 315 casting that flows over 450 cfm and I never made the openings or even the min. X section any bigger. It's all in the bowl and short turn. Compare that with a Dart 355 or even an AFR 357. The few cc's difference is negligible but the ports are entirely different. This is where average CSA might show something but not entirely.
