Hi Guys,
So I'm trying out some tall gears, and am using a solid spacer on the pinion. I've got two small issues: the preload is different when I check it clockwise (higher) vs counter clockwise. About 4 in-lbs difference.
Also, with the thinnest shim, I get around 5 in-lbs average preload. If I remove the shim, I get about 14 in-lbs counter clockwise and about 18 clockwise.
Is that too much for used bearings? This is a Ford 8.8 btw.
Thanks.
Thanks.
