I posted here not long ago about a tail shaft seal leaking on a PG. I got a newer tail shaft housing from ATI and installed that. I took my car to the track on Sat and made a couple of passes.
On the first pass, during the burnout, I'm confident that I felt the vibration that is causing my issues.
I can rule out the DS (I think). I had taken it to a driveline shop on 8/22 and they put it on their machine and checked the balance. They said it checked out perfectly.
I'm not excited about making adjustments, but something is not right.
I have made 4 passes and my car has hooked well off the line. My first pass Sat evening was a 1.29 60'
I'll check whatever needs checked. Please point me in the right directions and I'll report back with what everything measures out.
