Parts washers and Simple Green
4.2K views 27 replies 25 participants last post by  FASTFATBOY
How much do you cut it?
The bottle says 10:1 or more.
Is this stuff that strong?
#17 ·
Yup... Real life solvent, not water based... so it works better, and doesn't cause stuff to rust. It's called PSC 1000.
The pumps in the $99 parts washers are junk. You'll end up looking for something better... and while you're at it, plumb in an oil filter to keep the solvent cleaner, and make it last longer.
This is the pump you will eventually want. Plumb this into a remote oil filter adapter, and you're set. I had a write-up on here on how to do it... but I don't think search is working anymore, and a lot of the photos were on Photobucket. Tis' life. I think it was called 'Parts Washer Upgrade'.
Anyway, the pump...
https://www.ebay.com/itm/LITTLE-GIA...arts-Washer/221568121193?epid=1340957772&hash=item33967d3969:g:QVsAAOSwxzdaBmlx
Good Luck
