Parts Washer Upgrade!
35K views 67 replies 45 participants last post by  ponjohn
With a bunch of work needing done, I decided to break down and buy a real life $99 parts washer from Tractor Supply. It's the generic Chinese unit sold by Harbor Freight, and tons of other outlets. While there, I went ahead and bought a couple 5 gallon cans of their PSC 1000 solvent. Great stuff, as it works, and hardly has any odor! This is NOT the water based crap. I also added in a quart or two of Automatic Transmission Fluid to keep it from drying my hands and hopefully help minimize any surface rust. Hey, ATF is pretty good cleaner in it's own right...
Anyway, I got it home, noticed that the metal hose was screwed into a PLASTIC fitting! Yea, a metal hose you bend around to make it spray where you want! They must KNOW it's a bad idea, as they even include a spare fitting with the unit! LOL
Well, it worked great! ...for about a week. After a week, the pump quit working. I also noticed a bunch of dirt from parts floating around in the solvent. Instead of buying another CRAPPY pump, I decided it was time to UPGRADE.
I shopped around for a GOOD pump that wasn't too expensive, and decided to ad a FILTER to keep the solvent cleaner!
Here is the old pump. It's puny, extremely lightweight, and has a plastic fitting the metal wand attaches to!
Here is the new pump. The image on the Ebay ad does not show the cage on the front, but it comes with it. $64 and free shipping.
http://www.ebay.com/itm/LITTLE-GIANT-PE-2YSA-Pump-Parts-Washer-/221568121193?
Here's the unit all put together with the filter and METAL mounting that is bolted down for the wand. The filter makes a HUGE difference in how clear the solvent stays! HIGHLY recommended upgrade for anyone with a parts washer! The stronger pump has NO PROBLEM pumping through the filter, and sprays solvent with plenty of force. Pump is significantly larger than the stock one, and about 5X as heavy. lol I also purchased a parts washing brush with a hose that fits over the metal spray wand. It seals over the wand with what looks like a spark plug boot. It's a really nice, stiff brush and does a great job with the solvent spraying out of it. I believe the brush was around $20. The remote oil filter mount was $20, and takes a SBF oil filter! All of the fittings were sourced locally.
#2 ·
What are you using for solution?
#3 · (Edited)
First paragraph of the original post. :)
Real solvent, available from Tractor Supply. Good stuff, and very little odor. I use it in a basement garage, and cannot smell it.
It takes two cans to fill the parts washer. It's advertised as a 20 gallon, but only holds 10 gallons of solvent. It costs $40 for a 5 gallon can.
#6 ·
I can't imagine that filter will "live" very long. I always wanted to build a filter, a LONG time ago what was called a "luberfiner" filter was the object of my attention. These are a HUGE cartridge filter, used to be on the fender of many trucks, and was NOT expensive to buy. My recollection is that these cartridges were over a foot tall and maybe? 8" in dia?
#8 ·
I have one of the old safety clean wash tanks. They sit on a drum. I am not sure about that solution from tractor supply but I have used odorless mineral spirits and what works really well is to lift the pump up off the bottom raising it about 5-6 inches. Then fill those first few inches with water. The mineral spirits float on water and the dirt and grit settle into the water keeping the mineral spirits pretty clean and also eliminating the need to use allot of it.
Hard to do with the tub style tanks.
Going to give that tractor supply stuff a try. Mineral spirits have gotten outrageous.
#9 ·
I'm thinking about a tub underneath mine, with some sort of floating pump pickup. Frankly, most the time I just use gasoline. You can gasp if you want but the first time you use it for say, a pair of front wheel bearings, there's enough oil in there that the flash point is down a ways.
#11 ·
I have a washer built from an old sink and a little giant pump. I use a fram hp1 filter, it works great. Sink empties into a 5 gallon bucket underneath. Other side of the sink empties into used VP1 can, during disassembly parts are placed on this side, oil runs off into sink, and into can.
#13 ·
I might try this. I have the same washer and the pump is weak and the filter they include seems marginal at best. I'm assuming the SBF filter will need replaced fairly often?
Also, I used mineral spirits from Lowes (can't remember the brand) and it turned into a milky, nasty liquid that separates badly. So I'll give the solvent you posted a shot
Thanks for posting
#14 ·
good info here, thanks. my buddy bought one of those pieces of crap from harbor freight knowing it was a piece of crap but just needed something quick and cheap in a pinch. well he gets one use out of it then the pump quits, on his 3rd pump in 2 months, maybe the upgraded one you are showing would be worth buying.
#15 · (Edited)
I have the same parts-washer for 5 years using the same pump and also use tractor supply solvent ,its the real deal
I added a cheap inline fuel filter into the hose which lastsfor a while till it collapses but at 50 cents a filter its not a bad deal
so I but them by the dozen on ebay..I do like your new pump and filter arrangement though,I may upgrade also
These partswashers work OK for the home DIY mechanic ,its too bad there is nothing a step up unless you spend big bucks
#16 · (Edited)
In case you're looking for one, the fitting bolted to the side of the tank is a Showerhead fitting for PEX tubing. The 3/8" fuel line slid firmly over it, and didn't even require a hose clamp. The threaded end is 1/2" NPT. :)
#23 ·
It would be cool if you could set up some kind of sediment tank where the cleaner sets for a few mins, to let the hevy shit sink to the bottom and the light shit float to the top. Then have the pump pickup somewhere in the middle.
#29 ·
30 gallon barrel coated with epoxy on the inside after welding bracket to the inside of the barrel to hold the pump. Water in the bottom for sediment fall out. Same pump that came with the unit (Harbor Freight) and I welded legs on the bottom of the sump to hold it in place on the barrel.
The whole mess sits on an angle iron stand with wheels so it can be moved and I've been using a System One filter on it for years with no problems. The System One can of course be cleaned and reused.
#32 ·
Changed the filter today... As a matter of fact, this is the 2nd time I've changed it! The first one looked just like this one! DEFINITELY doing it's job, and keeps the solvent looking MUCH better than without the filtration!!!
