Hello All,
I am switching back to a standard volume pump over the hv pump.
I am right at a 1/2 inch for pan to pick clearance, which is right on the high side of where moroso recommends. Would you worry about it? Is there anything I can do to tighten it up without swapping the pickup?
Problem I was experiencing was it was getting into the accumulator going down the track. The accumulator prevented any starvation of oil, but I would rather not depend on it as the norm.
Also one thing I did find is there is a difference in the pickup location from the standard volume to the high volume pump.
One the standard volume pump, the pickup is located with a 1/2 inch of the rear of the pan. On the high volume pump, the pickup is approximately 4 inches from the rear of the pan. I am assuming this has to be done in order to accommodate the longer HV pump. It would definitely allow the pick up to suck air faster under g-force.
I was also curious to see where the oil level was in the pan. I have a moroso 7 quart 21017. With the pan level, 5 quarts puts the oil level above the windage tray. I am curious to see how much the oil level drops in the pan running at the oil pump at max speed. I plan on testing this on the engine stand by running the oil pump for about 5 minutes and seeing where the oil level falls to.
