oil pump blueprinting?
4.9K views 15 replies 12 participants last post by  slorob
Have a new melling oil pump for my 351w. And thought about having it blueprinted. Can anyone reccomemend someone?
#3 ·
Doug at Precision Oil Pumps offers blueprinted pumps for a variety of makes... Ford, Chevy, Mopar, Oldsmobile, Pontiac, etc.
He is also an FE specialist and offers a lot of specialty parts for those as well as the 427 SOHC.
Below are his 351W offerings.
Here is his main page.
If you want to port the pump, that will be on you.
Good Luck
#5 ·
Oil not fuel, anyways, I have always blueprinted mine by pulling the cover off, looking the gears over, making sure the bypass isn't stuck, dumping some oil on them and spinning them over by hand....:) I let the real blueprinting up to the manufacturers. Which involves checking all the clearance specs.
