I'm in the process of building a Pontiac 400 +.030 with a TRW forged flat top piston. I'm looking for a decent performance OEM Pontiac head. I'm confused with all the dam casting part numbers. Some heads come with small and large valves. Press or screw in rocker studs and different chamber volumes. Do all OEM Pontiac heads share the same port volumes and shapes? What is considered the Best all around head-casting number to use? The Ram-Air stuff is out of the question. I can do the grinding-porting and valve job myself. So, what do you Guys recommend, casting number, valve job, bowl percentages, valve job angles 30 deg or change to a 45, etc?
Thanks for looking,
Thanks for looking,
