Not shifting, electrical issue? MSD7AL-3/Biondo 450
1 reading
5.3K views 17 replies 5 participants last post by  nbman
Out for the first time this weekend with a new car (to me). I'm having a problem with the car coming up against the high chip at the shift point before it shifts.
Basically, car leaves hard, goes to 7000 rpm (high chip) and stays there for nearly a full second then shifts. It will shift every time on the stands in the pit, at various rpm settings. I've tried both shifting through rpm on the Mega 450, and through the RAS on the 7AL-3, with the same results both ways.
I've checked the linkage at the transmission to make sure it was properly adjusted in case it was not going all the way in under load, and it was good.
First attempts were shifting via the 450 delay box on rpm, set at 6500 shift point.
Second attempts were same with a shift point of 5500 rpm(thinking maybe there was some discrepancy in the readings)
Third attempt was with a 6300 rpm chip in the 7AL-3 ignition.
Same result every time. Car was professionally wired.
I do not currently have an alternator installed on the car (its ordered), so i'm leaning towards low voltage maybe??Aat the line voltmeter reads 12 v though. I was thinking maybe the shift solenoid takes just enough voltage from the system to screw with the electronics somehow?
Any help/ideas would be greatly appreciated.
As a side note, there's one more thing that's happening, maybe related or not. At about half track, after the shift happens, rpms jump by nearly 1000 in only a few hundredths.....
#3 ·
Shift solenoid is electric.
Since the car was new to me, i wasn't sure about the converter stall. At first i thought maybe it actually was shifting but converter was flashing to rev limiter or something funny like that so I flashed the converter and it stalled at 6000.
Transmission was supposedly just freshened by Wayne Horton by PO.
RPM jump was mentioned by fellow racer, also seen on replay on 450 box, and can be heard on video.
#8 ·
Actually, check it in this video. The original video was somehow cropped by the software. My buddy sent me this one that isn't cropped. In this version of the video, you can see the shifter. If you watch close, when it hits the shift point, the shifter moves ever so slightly, then after a second finally shifts, but seems to be very slow to shift. Should that not hammer that shift home instantly?
All throttle stop timers are at 0.00. Right now I'm only using it as SLE.
Video Here
#9 ·
What kind of shifter is it? Is the shifter new? We had one last year that needed to be lubed where it slid.
I had a similar problem 2 years ago it turned out to be the cable was getting tight.You really couldn't feel the difference but I noticed it on the data logger.It would shift at a different rpm every run,put a new cable in it and all was well.
#11 ·
The main question is why does it go past the shift point to the limiter before it shifts. During that run, shift point was set at 6500 rpm, and the car went to 7800 (limiter) before it shifted.
Shifter is a Phantom, with a Biondo electric solenoid. Neither are new. Shifter operation feels smooth but i will lube it.
I unhooked the cable at both ends and its as smooth as silk, not stiff or binding at all. Checked the adjustment from both ends, and all is in order there as well.
I ran it through several shifts just activating the solenoid, and it shifted without hesitation and much faster than it does during the run.
It seems that whatever it is, its only when running under load, as again, it shifts flawlessly on the stands with a fully charged battery.
#15 ·
i did take this trans apart and look at for Curtis Boggs i believe. it all looked good put it back together the way it was cut and cleaned the converter make sure fluid is full recheck the band loosen nut turn adjuster all the way in torque 72 in lbs back it out 3 1/2 turns if all else fails shift it manually no box hooked to it see if it shifts instantly or still with a delay?
#17 ·
Wayne, you are correct, you did look at this tranny/converter. When i spoke to you last fall, you said it was a spragless converter.
On one run it was shifted manually, and shifted fine, but still took the rpm jump at half track.
