I have an 89 Foxbody.
when I bought the car, it was as allegedly a turn key drag car.
Since I bought the car, we have done a lot of work to it. Now running a Mueller 427, running 98/108 turbo on Methanol.
9” rear end
Viking crusader shocks
Ladder bar + wishbone
275/60/15 MT radials
After we took to the track in March, my tuner was saying we need to put lighter springs on it.
They installed Landrum 55# springs
Since then, I have had issues getting traction off the line.
Sat night, I pretty much neutered the car. Left on 3 psi, pulled 20 degrees timing off the line and ramped to 8 psi on the dome over about 2 seconds and left it at 8 psi on the dome. I still blew the tires off. Left at 3750 on the 2 step.
The seller of the car said the radials had about 10 passes on them. Now my tuner says that I need new tires to hook and go. I have a set of new MT ET street radial pro’s. I also have a set of 28x10.5 pro bracket radials coming.
On my shock settings, I’m 14 clicks in on compression with 18 total clicks available. On rebound, I’m 14 clicks in as well with a total of 21 clicks available.
From what I gather, 110# springs are a common choice for fox body owners.
I made one good pass at OKC Thunder Valley. 1.3 60’ and 5.33 @ 138 mph
I do have shock sensors and a good data log from that run.
I would sure appreciate some input on this. The dang car ran in the high 4’ with a SBE 5.3 at 3200 pounds. Car now weighs around 2800 with 200 pound driver.
I have lots of videos. What I have noticed in the previous track visits, my car will hook off the line, but then break traction as the rear separates.
9” rear end
