I believe that Molnar rods are the best budget (China forging) rods that you can buy. They seem to be very strong and you see more and more 1500+hp guys using them.
It seems that Molnar has been extremely popular for a few years now, and with more products sold, will come more failures. Kinda reminds me when Callies came out with CompStar, it was the Go-To rods and crank over Eagle and Scat and after selling a bunch over a few years, failure rate started to show up as much as Eagle and Scat. Unfortunately, the same will happen with Molnar.
Is it because the quality is going down? I very much doubt that. I think it is just a numbers game.
You have to remember that 90-95% of connecting rod breakage is blamed on the rod itself, when in reality, it is closer to 10% (if that), that is a failure caused by the rod itself and nothing else causing it to fail (wrong rod for the application, wrongfully installed, bearing clearance issues and bearing failures, oiling issues, detonation, etc..).
If you are shopping for budget rods (less than $1,000us), it is hard to not go with Molar Power Adder rods. I think they are the best rod for that price point. If you want to go better, you will have to go to a Callies Ultra, Oliver Billet, Crower billet, Dyers, etc... and those will run you roughly $1,300us+ (sky is the limit) while the Molnar is pretty much half price ($700us ish).
Which direction you want to go is up to you: Less than $1,000, I think Molnar is the ONLY choice, above $1,000us, then that is a whole new discussion! And then there is the steel vs aluminum discussion, lol!
