Hey everyone, I am having an issue that I just cannot figure out and am totally stuck. I am working on my el camino, it is swapped with an 01 LQ4 that now has the gen 4 lq9 rods/pistons, deka 80 injectors, stock computer tuned with HP tuners by myself, GM 3 bar LS9 map sensor, VS racing 78/75 turbo, stock truck rails and fuel pressure regulator. I know it's not some peoples favorite, but just meant to be a fun street car. The injectors have the EV6 connector, and I got the Deutschworks connectors from summit and added them to the stock lq4 harness. I am running it off of one of Matt Happel's base tunes for a very similar combo to get started.
The swap is 99% done and I just can't drive it. Injectors 3,5,4,6 are not firing. I have checked every damn thing that I can think of.
I have bench tested them by adding ground and using power probe to supply power and they click, and vice versa by adding 12v and using the power probe to cycle them, and they work.
I have them run with the factory harness and pink 12v wires run to ignition 12v source, I have even ran an new dedicated wire directly to the battery for now to ensure they have proper power, no luck.
I have made damn sure that the pcm is grounded, and run all 4 grounds (pins 1 and 40 on both the blue and red connectors) straight to solid grounds, originally all together, and now each by themselves to rule out any interference, no luck.
I have checked continuity through all the wires, all check out okay.
I have swapped injectors across different cylinders, but identical results, the problem stays on cylinders 3,5,4,6.
Examining the pins on the connectors and they seem fine, no evidence of any pin drag issues.
I have had the key on for ignition power to injectors, and added ground with the power probe directly into the pcm connector pin with the power probe and I can hear the corresponding injector click, and all 4 work doing it this way, but it still wont fire them when running.
When cranking the motor over, they have 12v to the pink wires, and I can pick up the pulsed ground signal (right at the injector plug) from the pcm telling them to fire, yet they dont...
Fuel pressure is dead on 58psi while cranking.
Cylinders 1,7,2,8 all fire fine, and are wired exactly the same way. I can make the motor run and idle on just the 4, but by basically doubling all the values in my VE table (VE #'s at basically 95-100 through the 35-45kpa range...). But not matter what I do I cannot make the other 4 injectors fire and it is driving me absolutely nuts. They have good power supply, good ground, and good signal to fire.. why the hell do they not!? I am completely stumped and feeling defeated. It is a 4 hour round trip for me to work on the car and I have now been chasing this issue for 2 weeks trying to diagnose it and I am straight out of ideas. Please, if anyone has any thoughts I would love to hear them!
