LS Gen IV factory piston to bore clearance
9.6K views 9 replies 7 participants last post by  Third Gen Racer
What is the factory piston to bore spec for a factory gen IV coated piston such as piston # 89060486
#3 · (Edited)
Having done near 100 warranty fixes for the GM shops in phx area. Most all of the piston noise is from the bore being to big for said piston. I had to talk to a GM engineer when I was supplied with pistons from the dealership to bore and hone for warranty replacement.
It took several days for said engineers to come up with an answer. The final result was .0008 to.001. Measured at the pin centerline. Seems to have worked as there have been no comebacks
#4 ·
I've got access to Alldata and went through the factory specifications for an '09 LMG 5.3L, didn't find any specific piston to bore clearance specifications. The bore is listed at "3.779 to 3.78". There are dozens of specifications for pin to piston and rings to pistons but nothing relating bore to piston.
