Hey gents, been a while! What's the latest craze on main bearing clearances in Aluminum blocks?
My compstar ccw crank measured right at 2.5590 +/- .0002 on all 5 throws so I fit a set of coated X bearings in the block. Got .0034 .0038 .0030 .0036 .0035 zeroing out the dial bore gauge to mic on each journal. Seems a little loose maybe, especially with aluminum blocks allegedly gaining a thou of clearance at operating temp. Not sure what to think about #3 being a tick tight.
Will be 1000-1200hp turbo deal, CCW crank as mentioned, 10355 pump, and probably 10-30 oil as per Johnson lifter guidelines (i.e. they say nothing heavier than 40wt).
What do we think? Throw half STD in each except #3??
