Just installed a new line lock. Took it to the track using drag radials and it did not hold good. The car has front drums with the muscle care brake system. Any suggestions?
I THINK HE WAS TALKING ABOUT THE STARTING LINE!!! Didn't mean to yell, but I ain't typing that again!!!Reading through this
If you are sliding your front tires......quit being a pussy and use that little pedal on the far right, and if you cannot start your burnout in high gear, take your time, like maybe .2 seconds to get it there.![]()
If his line lock is working correctly, he will have no front braking at all by hitting the line lock first.....try this
activate the lineloc, pump up brakes, stab the throttle
