Lightest 400 hp engine?
12K views 83 replies 49 participants last post by  Badrooster
Looking for your input on the lightest 400 hp engine that a normal man can afford.
Need something that can make 150 passes without problems.
Will have a glide with a brake.
I can make my own adaptors.
Post weights if you can.
Thinking Subaru?
#7 ·
won't make it 15 passes let alone 150.
LS/LQ or SBF. sorry, you're going to need to trade reliability for a little bit of weight on your budget. sure, you could do like some honda b18 or some shit with a refrigerator sized turbo on it, but you asked for it to last and cost normal.
#6 ·
Ls1 or ls2 with a cam. 400-430lbs will make easy 400hp. Looks like your wanting real light.. nevermind
Yes trying to get lighter than that.
Loved my LS, but looking for something different.
#10 ·
4g63 or try a 4 cylinder sprint motor
#15 ·
You have a slight problem...
Light as in lighter than any domestic small block. But to use with a powerglide.
In what car is this combo gonna be in?
2JZ-GTE can pair up neatly with a glide but its fairly heavy.
Toyotas 3S-GTE, Mitsus 4g63, Rotarys like 13b-20b will surpass the horsepower rating, but i havent seen one yet paired to a glide. mainly im guessing because of torque or drivetrain loss issues.
#19 ·
GM Ecotec LNF engine. 260 HP stock and RWD in Solstice GXP and Sky Redline. Easy to mod to 400 Hp. Im sure a glide can be made to work behind it
#27 ·
id try the Mitsubishi 4G63, just make sure u get a 6-bolt and rock out.
#31 ·
turbo honda b series, but for that kind of power im not sure it can be cheap. 2.3l turbo ford. once again for the power im not sure it will be cheap
