What should lifter to bore clearance be on solid roller lifter in sbc
Its a shp block crower lifters
Thanks benno
Thanks benno
Thanks benno
if the axle oiling hole is edm from the oil band to the axle, the bore clearance wont matter, as the band has full supply.
as for top oiling, we put a .015-.020 or so deep nick from the band to the oil hole to provide oil to the pushrod/rocker
we typically set up at .0017-.0018 on new bores/lifters in an iron block, and with the lifter modified, i have never had issues
with alum, i will set up .0002 or so tighter
I feel this gives us the best control of oil spilling out of the lifter bores, and also provides plenty of oil for the pushrod/rocker
We also oil the lifter galleys from both ends of the block, with .063 restrictors in the 4 corners
We have recently been switching to a full body style lifter without the band for support, and we mod those as well to provide oiling.
YMMV and all that..lol. This is just what has worked for us
