Thanks for the compliment. I had a lot of good people helping with the build, and got a ton of advice on YB. To me, the only dumb question is the one you don't ask! The quality of you build looks fantastic. You could also just add a limiter to the rear end so it can only hang/extend so far, but that doesn't help you with you street set up. My car started out on slicks, and then we converted to radials. That change was a lot of trial and error. I was ready to give up on the radials when Greg talked me into one more track rental to test. It was switching the car from street to track, when I realized the reason I was knocking the tire off at the hit. I was still running the shocks mid stroke for street driving, but we had the rear bars set up to extend. Thats when I flipped the mounts and lowered the springs. Went right down the track 6 straight passes after making that change. The advice about extension you have been given is good advice, but it probably doesn't take into account this is not just a race only car. Those rear shocks springs are brand new, unused. You should be able to get good money for them, or you can check with who you bought them from and see if they can work with you in some way to get you into something that fits the bill for you. I dealt with Eric Saffell at AFCO for my stuff. This was his suggestion on shock length when I converted to his BGX shocks.
There are a couple of advantages that come to mind. A longer shock can help the housing fall out further making tire removal easier, given you can still achieve a correct ride height for the shock. We don’t want to have the shock too close to bottoming out. The second reason is if the plan is to run the car with a lot of anti-squat causing the car to separate greatly at launch. We see this with radial tire cars where we need to separate the car 2-3 inches and some shocks may not allow that much extension travel. So, if you have a plan to run the radial tire and will make the rear suspension adjustment to maximize your combo, a longer shock will definitely help.
