I have a 572 BBC pump gas motor I am building for my street car. It has a Mark IV Bowtie 10.2 block and I have a Merlin single plane intake with recessed distributor hole for using a stock style distributor with the tall deck block. I have a standard length MSD HEI distributor that does not have a slip collar. I dropped the distributor in and everything looks ok as far as I can tell but with the recessed hole its impossible to see for sure that the distributor collar is sitting on the intake or if its bottomed out somewhere else before the collar makes it to the intake. Is there a way to tell for sure? Where would the distributor bottom out first if the intake vs. collar were not right? i have a Melling M77 pump and a ARP oil pump shaft and a Lunati hyd roller cam. Thanks
