Holley smart coil dwell time?
14K views 17 replies 9 participants last post by  Third Gen Racer
Pump E85, 4hp per ci, Holley 556-112 coils, big wire kit, 12v no alternator. How much dwell time should I be at peak?
#3 ·
That sounds like how I have mine setup. Mine isn't running "clean" the last .4 or so of the run. I originally had an issue with it going lean (blow through) but have corrected that. But still isn't clean through the end of the run. I thought maybe I was experiencing spark blow out. R5671A-8 @ .020.
Should I close the gap some?
260643
#4 ·
After more review I see my dwell was actually running at 5.6. Per Vol Comp Ign Dwell trace. Battery was at 12.2
Per V4 instructions
  • Base Ign Dwell – Indicates the base ignition dwell, that is either from the user input single dwell value, base dwell table, or hard coded from the Ignition Type selected. This is the nominal value at 13.8 battery volts. More or less voltage will change this value, which is indicated by the “Vol Comp Ign Dwell” internal parameter.
  • Vol Comp Ign Dwell – This is the actual coil dwell, which is based on the Base Ign Dwell, and modified by battery voltage.
