Hi
So I have an issue with getting my car to idle. Or to be more accurate, I am having trouble getting the IAC set at 3%.
What I am finding is that when I adjust the throttle blades to get the IAC near 3% the engine surges. When I open the throttle blades more the engine revs high and the IAC is at 0%.
I have tested the IAC and appears to be working fine.
The engine is running rich (10.2 - 13.4) and I have checked for vacuum leaks.
Where do I start with this? what's the logic? Do I try to lean the tune out a bit to get the AFR back? Do I need to drill a bigger hole in the TB?
As you can tell, I am a noob to this.
Here's my spec:
LS1 running 220 3.90 Trickflow heads
Comp Ultra-gold Arc 1.72 Rockers
7.550 BTR Pushrods
BTR Stage II NA Cam 227/234 .614"/.576" 113+2
Ported FAST 90
NW 90mm TB
FAST 60lb Injectors
Any help would be much appreciated.
Ta
Here's my spec:
7.550 BTR Pushrods
Ported FAST 90
NW 90mm TB
FAST 60lb Injectors
Ta
