Holley dominator no fuel pump
5.6K views 16 replies 7 participants last post by  Pro Stock John
Doing a 82 SWB Sliverodo. Motor is a LS6 out of a ZO6 2001 vet. Transmision is a 4L80e. I’ve got 12v and ground ran to the battery small red wire to 12v Constant red and white wire to keyed 12v. Black wire to a good clean ground. Each coil harness to back side of the heads. Coils are firing. Fuel pump will not come on. It was coming on yesterday but only when you first turned the key on but not when cracking. Today it want come on at all. No power from the pump wire green wire. What am I missing here? I’ve uploaded two different base tunes no help.
#9 ·
Thats one thing I dont let the Holley power .
I have my fuel pump directly to the battery using a SS relay . The only thing the Holley does it pulse the relay with a PWM output . Pump comes on when RPM is detected
Before using PWM , I just used a toggle . Didnt like the fuel pump running while the key is on .
I also power my ECU with a toggle so I can look at the holley without the key on and adjust the fuel pump PWM output without key .
#11 ·
Well had just a little to much help today. Friend of mine came over and wanted to help some. So I gave him some cutters and told him to cut some zip ties off I had a better way to hang them. Well he cut them off had to leave so we talked a little. After he was gone I got under there and it made me sick. He had cut my usb cable in half. Witch would be no big deal but mines hard wired in.
#16 ·
Mines got like four wires coming from the ECU. Black, Red, White, and Yellow. I got a new one same color wires. The wires coming from the ECU have a fiber of some kind in with the wire. Wire is aluminum. New harness is copper no fiber. Went ahead and made the repair. Did not work. I ether I’ve got to remove the fiber strands or not solder them.
