Hmm why did valve break.
1 reading
5K views 38 replies 14 participants last post by  Steve.k
We seemingly had a valve break on a stainless exh. Not sure why. Lots of clearance and not even hitting the 6800 rev limiter. Could only find a couple small fragments of valve head. Piston seems remarkably tough. It did better than cylinder. Any ideas? Necked down qualfast valves.
#11 ·
Thanks Jim. This is 400 block .030 there is some relief left on exh side. I cannot see anywhere the others were hitting wall. It split number 6 so will need sleeve. I do have another block we may use instead at any rate needs tore down. Everyone stepped up in this class so i have another recipe that was 650 hp with single 1050. Might go that way.
#14 ·
We believe they are. I’ll recheck pressures on rest. Never know. We set high typically. Cam calls for 120/320 I think we are 160/380. I do have about 5 other engines out with these valves. Their still going so hard to say. One thing about these thinwalls. When something falls in usually cracks cylinders. 🥲🙈
#35 ·
The most common problem that causes valves to break is the valve seats not being concentric with the valves. Concentricity must be checked and corrected when the valves are installed/ground. If the valve seats are not concentric the valve will contact the seat at different locations (angles), due to the fact that the valves rotate while running. This will cause the valves to bend very slightly and just like bending a piece of wire back and forth, the valve stem will eventually snap. Quality machine shops will always check valve concentricity before the heads leave the shop.
  • Like
Reactions: Steve.k and CFMCNC
